About Pafta Export
hiryu
Good evening everyone, when I export the layout I created by adding "layout blocks" in ideCAD static 7 with dwg extension and open it in Autocad, there is only a layer named "Standard" in the layers. However, when I export the dwg by drawing the project whose calculation is completed from the "Drawing" menu, the relevant layers (Beam, Column, Reinforcement Text, etc.) are created in Autocad. Am I doing something wrong with the layout process?
"hiryu":zonpy51v" said:
Good evening everyone, when I export the layout I created by adding "layout blocks" in ideCAD static 7 with dwg extension and open it in Autocad, only the layer named "Standard" is found in the layers. When I export the dwg by drawing from the "Drawing" menu, the relevant layers (Beam, Column, Reinforcement Text, etc.) are created in Autocad. Am I doing something wrong in the layout process?
Hello, As you wrote, the program transfers the layout blocks in the standard layer. For pen thickness settings, the procedures described in the following title will help you:
The layout block should not be used to continue working in Autocad. The purpose of creating a layout block is to prepare the drawing sheet to be sent to the plotter.
Hello, I faced the same problem. In fact, throwing the sheet with its layers would be an application that would make things much easier. I think it will be useful if it can be added to the new version.
Hello, It's been a while since this topic, but I thought it would be appropriate to continue here in order not to open a new topic. In response to Ms. Arzu: Although you have thought of exporting from this map directly for the plotter, this process is used for a different purpose for all existing users. As other participants have stated, after I prepare the drawings one by one, I transfer the layout to AutoCAD for final corrections before printing. Because doing some work in the drawing part of Idecad is really torture. As far as I can see, layers can already come when exporting (from normal drawings), so this process is already possible. It shouldn't be too hard to put this into export from the layout in the same way. We would be glad if you take into account the user comments on this issue. Good work Yagmur Can KOÇAK
