About Lovers Deflection Design
miralay
While the program is designing purlin, it does not fully comply with the rules in TÇY2016 Chapter 15. Use limit state combinations according to Chapter 15; G+Q G+0.5S G+0.5Q G+0.5Q+W The program only checks the L/240 value in the G+Q combination. This check applies to normal floor joists. Considering that there will be no live load on most roofs, the main determining combination would be G+0.5S. The deflection condition here is L/300. Also, for lovers, it would be nice if we could watch the deflection control from the 3D window outside the report. I wish you good work.
A fix. In normal floor slabs, the deflection limit is l/360 due to the live load, and the deflection limit is l/240 due to the live load on the roof.
Hello there; You can control the snow load in a simple project by entering an exaggerated value in your project in order to see that deflection control can be made according to the G+Q and G+0.5Q combinations. Only that combination is printed on the design screen and reports, whichever gives an unfavorable result. If you read the articles about the combinations to be controlled in the Steel Structures Regulation, it is understood that these two are the combinations that need to be checked in elements such as secondary beam, purlin, steel beam. As you will see in the program trainings regarding the deflection limit values, the values that come as l/240 for the secondary beams and purlins and as l/360 for the main beams are only the set values of the projects. The program does not detect that your building element is on the roof or mezzanine or is a console element and does not automatically change the deflection limit accordingly, this is under user control. In your projects, when necessary, you should select the element and intervene in the deflection limit from the properties - design tab. You can view the deflection results of the purlins in the analysis tab, if you select the perspective screen, right-click analysis view, steel design deflection limit and activate the show purlins. Good work.
