Murat Kanıcı
Hello, 1) We cannot see the steel joint details in the reports. 2) Even if the joins do not save, it seems that there is no problem in the structure when we get the report. 3) It seems that there is no problem in the system even if I make 1 mm plate thickness in some joint details (like forehead and gusset joint detail). 4) I make a symmetrical jointed column base joint, but while it saves 30 mm plate thickness in one, it wants a plate thickness of approximately 70 mm in the other. Also, as I mentioned in item 3, when I combine it with a rigid column foot joint on both axes, even if I make the plate 1 mm, there is no problem.
