About Geometry Control
yusufgok
What could be the reason why I get geometry control error during analysis, although I only get small angle object warning during analysis? The center of mass and stiffness shows outside the structure. Could it have something to do with it? PROJECT LINK :
Hi, connect the B017 beam to the P015 curtain at the nodal point on all floors. In this case, the analysis will be done in the project. Some other notes; -2nd. no foundation is defined under the P001 and P013 curtains in the basement. - We recommend modeling the elevator shaft without leveling the curtains and as a flat raft foundation.
Good work
Mr. levent, can you look at the kz21 beam? Can we add the possibility of defining ribs in this way for application to the program?
Hello, Mr. Levent, do the beams that are not connected perpendicularly to the column or curtain in the style of B019 in the image you posted create a problem in terms of the statics of the building? Sent from my SNE-LX1 using Tapatalk
