About fonts
bartayd
Can we put all fonts in autocad to idecad file? or is the standard autocad font available in idecad? Good luck with
ideCAD uses Windows fonts. Since there are no autocad fonts in Windows, it is not possible to use those fonts in the same way, but you can use similar ones.
"bartayd":2mjuw5lp" said:
what do you think is the most stable static font or the most used in idecad
The settings used when you open the program with a template are appropriate. Why do you need such a question, if you explain the subject, we can provide more accurate help. Normally, this is You shouldn't need any kind of editing.
