Hello, I have a small mosque project right now. I modeled the dome by sitting on the spring beams supported by the columns. When I do the analysis, the dome analysis is not done, I also have the dome analysis done, but neither sees the dome nor reports its results nor transfers load from the dome to the beams. the entire information box appears with a pale color that cannot be processed. Should I do something different to do this analysis. I can see the translation and section effects from the shell design results menu, but I can't see its interaction with the structure. I would appreciate it if those with experience could help. Thank you for your interest in advance.
