Good day idecad 1-I created cork flooring in the project I designed, are my calculation axes suitable for the idenin mantle 2- while I was browsing the forum (with a second system (with the project, hidden beams and vertical carriers connected to each other), TDY irregularity controls and earthquake effects on the plate should be checked) I read something about how to do this Can you explain 3-the reason why the structure I designed is two different road elevations as in the picture, is the solution in two different elevations together or I should make a separate distinction link
Log in or register now.
thanks, good work
