About contour line and import
When I import a file, the architectural drawing on the page moves beyond the contour lines, I tried to fix it with the move command, but how can I fix it?
"ali firat kardaş":hxuf4xmv" said:
when I import a file, the architectural drawing on the page moves beyond the contour lines, I tried to fix it with the move command, how can I fix it?
Hello, you did not write what kind of situation you encountered after the move command. Edit the scale of the imported dwg drawing to be 1 m=1 unit. You can do this with the scale command. Then click the move command. Select the entire drawing. Right click. Select the point you want to originate in the dwg drawing. Move the mouse to the origin point of the program and left click.
In idecad statics, my contour lines that appear before importing the architectural project disappear when I import them, the lines are not visible when drawing a new contour line, how can I make them visible? in the same way, while the column is drawing, the column is not visible, but when the drawing process is completed, it is visible. There is no problem without a base.
"meryemakdil":3vayoiwr" said:
idecad's contour lines, which appear before importing the architectural project in statics, disappear when I import them. /quote] Add the IdeCAD project file you have imported.
"meryemakdil":1ennk9by" said:
https://we.tl/t-kgRgaMDEps does not appear when placing columns and beams. Previously, column beam shifts were visible when setting offset with space. Previews of beams, columns and other objects will appear during data entry.
