About Continuous Basic
serkan zorlu
There is a lot of indentation in the building due to the land of the project I gave the download link, you will understand my problem better when the project is examined. .I wanted to define the foundation beam under some recesses but I couldn't.. what should I do? I will be very grateful if my project is examined in general terms.. I have seen the benefits of the forum. I would like to thank all my friends for their efforts.. I am trying not to make any mistakes as you are just at the beginning of the road.. I would like to thank everyone who contributed to this effort....
Re: ABOUT CONTINUOUS FOUNDATION Hello, Indents and protrusions on the side of the building are not very suitable for defining the continuous foundation system. You can try the beamless raft system.
Re: ABOUT CONTINUOUS FOUNDATION Mr. Serkan Zorlu My suggestions for the project. (LET US AIM TO USE SEMI-RIGID DIAPHRAGM SOLUTION OPTION OF THE PROGRAM. GIVES VERY GOOD RESULTS.) 1- Basically: - connect the foundations from column to column as seen in the appendix "Foundation" (blue line) - your curtains accept both ends as support and lay a foundation - better make a solution foundation 60 cm raft without beams (red line) 2- When you make the foundation raft, you can solve the superstructure interactively. 3- choose the ductility high 4- take the structural system coefficient 7 5- make the column narrow side dimensions 30 cm 6- install the ribs on the short span beams 7- fix the support of the ladder, solve the system as a semi-rigid diaphragm 8- your earthquake curtains are low, if you can put both add direction 9- join the K02 beam in the engine room to the S18-19 column 10- the contractors want no beams to be placed between the columns as in the front columns (as it divides the rooms) avoid this approach as much as possible. 11- If the above suggestions are applied, your project will not have any errors as a result of calculation. Take it easy Unver ÖZCAN
