During my doctoral education, I had studies on this subject. In order to avoid resonance and its consequences, the most important solution for us engineers is to design according to the ground condition. Two methods can be followed in this design: 1) By reducing the natural period of the building 2) By increasing the natural period of the building, the design is changed by moving the structure away from the natural vibration period of the ground. Changing the building form to reduce the building natural period: - reducing the height - reducing the slenderness ratio - widening the base of the building Increasing the rigidity: - using shear walls - increasing the number of shear walls - strengthening the outer edges of the building Reducing the mass: - using light load-bearing system - using light non-bearing elements methods can be used. In order to increase the natural period of the building; Methods such as changing the building form - increasing the height - increasing the slenderness ratio Reducing the rigidity - rigid framed structure - increasing the frame openings can be preferred. You can't explain to the owners, contractors or construction companies the reasons for making the building too rigid to get away from the ground dominant period, what the f..k ? They say get lost you poor bastard. Secondly, if you try to make the structure less rigid than necessary to get away from the ground dominance period, you start to compromise on structural safety, so no one will award you a medal for this approach. Here, it is possible to measure the rigidity or less rigidity of the structure, as an example, as the number of 0.1xKat. It's an approach that has been going on for years, but it's a really healthy parameter (according to the system, of course). On the other hand, in case of resonance, there is no such thing as the building will collapse to the ground. The structure is damaged in the earthquake and the ground, more precisely, moves away from the dominant period of the earthquake. Of course, no one wants the building to be damaged in an earthquake, but this is what will happen. On the other hand, for a perfect resonance condition, the earthquake should have a constant frequency for at least 10-15 cycles and in the 1st period of the structure with the highest effective modal mass, I am neither such a source nor such a continuous medium (the waves originate from the source). I know (in matlab, you can test it with sine waves of various frequencies at first with single degrees of freedom and then with mathematical models of multi-degree-of-freedom systems by performing dynamic analyzes in the time domain, I know because I did it when I write my master's thesis). At least 10-15 cycles at a fixed frequency, for example, if the 1st period of the building were 0.7 seconds, it would take 7 to 10.5 seconds. There is no such seismic wave (by the way, just because I haven't seen it doesn't mean it doesn't exist
). So far, I have studied the fourier spectrum of many earthquake waves, and such waves come only from long-period but very distant sources with various frequencies attenuated, and their amplitudes are naturally low. In this respect they should be harmless (theoretically ???). So what? keep going.
