About beam dimensions
inci
Hello, when my project was checked in the building inspection, he said the condition of H> ln/10 in beam dimensions. But such a condition does not appear in tbdy2018 and the program does not take this condition into account. How should I explain?
Isn't that something the program would consider? You (if necessary) will determine your beams in this way as a designer. Ask the building inspection according to which article of the regulation they want this requirement.
' According to this, if you determine the size by following the rules in the table, there is no need to make a separate deflection calculation for reinforced concrete elements.
This rule, which the building inspection company says, is the beam height / span ratio that will not require deflection calculation. Since ideCAD performs deflection control, you do not have to follow such a rule.
