Hi, As seen in the attached photo, it shows some floors as static plans when working with the Architecture lock. gives the names of beams and columns that should not be in the architectural plan. Nothing changes when shift+tab switches between architecture/static pattern plan, in short, Idecad Architecture runs Idecad Static on some floors. The static is not even unlocked. I tried new projects, reset the settings, it still doesn't work. What is the reason for this error? I never had such a problem before. How can it be fixed? Good work.
