Abnormal build period
qwerty
Dear ide, Where am I doing wrong in the project? When you solve the project without including the stairs, there is no problem with the period, but when it is included, the construction period is a very abnormal value. Can you review and get back to me?
Re: Unusual BUILDING PERIOD Hello, The ladder in the upper part of your building, in the area where P03, P07 is located, looks faulty, the arms are not connected to each other. Use the ladder I added in the message instead of this ladder. Build periods will return to normal after using this ladder. Link of the corrected project:
Periods of the corrected project: The staircase was made according to the geometric features of the staircase in your building. After downloading the ladder, copy it to the stair folder under the program folder to use it.
"HakanŞahin":3pj8y4c4" said:
Hi, The ladder at the top of your building, in the area where P03, P07 is located, looks wrong, the arms do not connect to each other. Use the ladder I added in the message instead of this ladder After using this ladder, the building periods will return to normal. Link of the edited project:
Periods of the edited project: The ladder was made according to the geometric features of the ladder in your building. To use after downloading the ladder, it is under the folder
First of all, thank you for your answer. How can I detect the errors you detected as a user? (Although it shows the ladder with a red arrow in the analysis display options, you can see that the types of the error are your detection and for the solution. that I should do what you need to do (by creating a new ladder, not a type ladder)? Errors: "In your structure, the top The ladder in the area where ta, P03, P07 looks faulty, the arms do not connect. Use the ladder I added to the message instead of this ladder..." I used the type ladders in the program's folder and entered the ladder values in accordance with the architectural and static dimensions. But I can't understand how I made the wrong connection. If I am not mistaken, it is not the type ladder in the ladder file because you have encountered a similar situation. But the new specially created staircase and the type staircase are already the same, why is it wrong when we use a type staircase, and the problem is solved when we create a new staircase specific to the project?
As a user, you will not be in contact with the technical service both in this Forum and by phone. Sometimes experienced technical service engineers can understand the situations that you can't see very rarely. The program is constantly developed so that users can understand the situations that you have forwarded to the technical service in future versions. Thank you for reporting this situation to technical service.
"Ismail Hakki Besler":pnvjr2j0" said:
As a user, you, as a user, will not be in contact with the technical service both in this Forum environment and by phone. Sometimes, experienced technical service engineers can understand the situations that you rarely see. The program is constantly being developed so that they can understand this situation. Thank you for informing the technical service. Our wishes should not be misunderstood.We will be happy if we can make a positive contribution to something with our well-intentioned learning and understanding efforts. Thank you for your understanding.
