I wish everyone good work and success in their work. I wish the ide officials success in their work. I had the opportunity to examine the semi-rigid diaphragm in detail with the document I obtained in the forum. The results I obtained are as follows, giving dangerous results as a result of the rigid diaphragm in buildings with A2 irregularity. The main reason for this is the floors. Structures with A2 irregularity occur in structures that are not geometrically uniform and there are certain conditions in the regulation. These conditions are issues such as gross area void area ratio and slab discontinuity. My main question is that in the program A2 and A3 irregularities, it is stated that the user checked, of course, we, as engineers, need to examine the structure, we can manually calculate and control the void ratio from the conditions in the regulation, but how should we use to check the slab discontinuity, can we share 2 different types of pictures from the shell results? ? Or can detailed information be obtained by other methods? Also, in order to detect this slab discontinuity, do we need to analyze the system again semi-rigid (because semi-rigid slabs are calculated) or do we need to perform rigid analysis? Good work to all my colleagues OMER FARUK ÇAKIL INS. ENG
