"dabanlio":pzwfcpbt" said:
1 - Considering the column shear forces, the moment calculated in the calculation section in question, and the moment arm, how does the moment arise from the shear forces parallel to the moment arm? (After tya and tyu calculation, there is a transformation calculation for V calculation I think I didn't understand it)
For column top and bottom nodal points, moment column vertical column shear forces are taken into account. This process is done for 4 earthquake loads in 2 directions. For example, in EX1 C01 column, global FXi force is taken into account and the angle of the axis is projected As a result, for the same moment arm, by taking shear forces perpendicular to the moment column, we perform an investigation in all 4 directions
Is the location and cross section of this control correct (xx direction / mid-slab) ? (The axis and the line are in the coincident state. If the axis is used to calculate the moment arm of the control section and the line determines the control section, should the two always be in the coincident state?)
Passing through C01-C02 and C03 to obtain the moment arm you have shown in the drawing You need to select the axle and give the delta amount up to "-e". The main point here is to find the moment with respect to the selected axis. So if you give the delta zero, the moment will be on the axis. You increase the moment arm with delta. The line knows the slab section. (such as thickness and width). As for your question, the two don't have to coincide. With Delta, you can change the moment column as much as you want.
Does the check also need to be done in the direction of the other perpendicular (aa) section?
It's okay to do it. But there is no interrupted gap in that direction. I don't think it's necessary for TDY. [quote ="dabanlio"
zwfcpbt"]4 - Does concrete compressive shrinkage in the explanations mean concrete tensile strength?[/quote] The stress resulting from the moment is compared with fcd
Sigma= Moment/Strength moment < Concrete characteristic tensile calculation strength is being controlled.
Is it recommended to lay additional reinforcement when there is insufficiency?
" There is the amount of reinforcement that that section can carry with that moment and the As value is given accordingly. Otherwise, the section will not carry the moment. It is called ".
Is the system considered to be able to transfer earthquake loads safely with the additional reinforcements suggested in case of insufficiency, and therefore is it possible to make a solution with a rigid diaphragm?
This is the purpose of this investigation. It is essential to show that the earthquake loads are transferred safely. However, if you wish instead of this method, you can use another method. Good work, take it easy.
