A1 disorder
*I think you are talking about the A1 irregularity... There are perimeter curtains on 4 axis in the basement floor. It is normal for A1 irregularity to occur. In addition, as mentioned before, A1 and B2 type Irregularities are irregularities related to the reason for choosing the calculation method. These irregularities have no effect on TDY 2007 when dynamic analysis is performed) *The X coordinates of the columns S05 and S08 to which you connect the K19 beam are not the same. If the beam is defined by aligning the node of the column S08 with S05, your problem with the beam is solved.
