gives an error that interrupt security is not provided in a single curtain in my project. The project was a bit of a struggle as there are beams over 7.5 meters
hi, i changed the tooth spacings, let the columns be connected with beams even if they are diagonally, they don't make teeth anyway, very little of the beam connection area on the side axis, I made deep beams there, the coating load is 0.35, the live load is 0.2, ideal values for houses... 0.35 of the loads including the walls...you can reduce the wall loads on the beams when you do them I hope there will be no problem
