A few suggestions that I would like to add to the program
miralay
Good work dear Ide family. I have a few suggestions that I would like to see in the program in general. I have listed as below. 1-) Adding the ribbon menu to the program and having a classic or ribbon menu option. 2-) Making general improvements regarding the finite elements of multi-armed curtains. From time to time, the finite elements of these curtain arms do not connect with each other. 3-) Calculating the mass and center of stiffness display while the column-beam and curtain elements are being entered, and showing them instantly on the screen. We have to analyze every time for possible changes in the current situation. 4-) To be able to apply a change made to a column beam or curtain element on one floor at the same time on all floors. For example, a column whose dimensions are changed on the ground floor is brought to the same dimensions on all floors. (Maybe there is. I may not know.) 5-) Linking the drawings with the model and updating the drawings when the model is updated. While doing this, preserving the manual operations on the drawings, only changing the part that has undergone revision. I know this item is difficult. However, especially in our country, there are frequent revisions in buildings. For example, we take the formwork plan of a building we are modeling and measure it on idecad and finish it. Then, when we have the same mold plan taken again, even in a possible minor revision, all manual operations are cancelled.
Re: A Few Suggestions Also, it would be nice to have a three-dimensional idecad model displayer that can work on phones and tablets for the construction site.
"miralay":1fpkjnwb" said:
Good work dear İde family. I have a few suggestions that I would like to see in the program in general. I have listed them as follows. 1-) Adding the ribbon menu to the program and having a classic or ribbon menu option. 2-) Multi-armed curtains Making general improvements about finite elements. From time to time, the finite elements of these curtain arms are not connected with each other. 3-) The display of the center of mass and stiffness is calculated and instantly displayed on the screen while the column-beam and curtain elements are entered. Analysis every time for possible changes in the current situation. 4-) To be able to apply a change made to a column beam or curtain element on one floor at the same time on all floors, for example, a column whose dimensions are changed on the ground floor is brought to the same dimensions on all floors (Maybe there is. I may not know.) 5- ) Linking the drawings with the model and updating the drawings when the model is updated. preserving the manual operations performed, replacing only the part undergoing revision. I know this item is difficult. However, especially in our country, there are frequent revisions in buildings. For example, we take the formwork plan of a building we are modeling and measure it on idecad and finish it. Later, when we have the same mold plan taken again, even with a possible minor revision, all manual operations are canceled.
Hello, could you add a sample project for the 2nd item? For item 3, the center of stiffness is found according to the shear forces taken by the vertical carrier elements. Therefore, analysis is required for the calculation of element shear forces. For item 4, it is possible to change the dimensions at once by selecting an element on all floors and entering its properties. For columns there is a "column sizes" command. If you select the column and click on the column dimensions, you can mark the floor you want in the dialog that opens. Thank you for your attention.
