8.5 update curtain bug
dester
In my project, which is defined as a 25/245 column, this element was seen as an automatic panel, but with the ide 8.500 update, it saw it as a column and added column reinforcement in the column application. Probably this was omitted in the update. I will be glad if you check
In the modeling with the column element, although the wall design is made by considering the 1/7 ratio in the reinforced concrete design, it is modeled as a bar element in the analysis model. This may not make much difference in a section such as 25x175, but it causes a deviation from the real behavior at a rate of 1/10. It is best to model the curtains as shells, which is required by the new regulation. Probably not for this reason in the new version.
The new regulation obliges curtains to be modeled as shells. For this reason, stick modeling for curtains has been removed. Until the new regulation is issued, the elements entered as curtains will be allowed to be modeled as bars. However, this option will also be removed when the regulation comes into force.
