I think I have a misunderstanding or misinterpretation here. Hn<= 25m item 2.5.1.6 (b) In the case of the normal system (this is 13m for the hollow cassette, without beams), the normal altar, the system consisting of only frames without curtains is allowed, while a system with curtains is quite allowed. item 2.5.3. or, when H will exceed 25 m and you will use normal ductility, you should cast a curtain with normal ductility with alphas>=0.75, the regulation says. I think this is your mistake about R in this update. With this update, you are saying that if there is a curtain in the system, you cannot choose a normal altar building (you can choose mixed or high), which makes this comment already in table 2.5. If there was such a logic, there would not have been an expression such as the ductile is normal and R=4 is taken in the section where the column and curtains are together, in the table 2.5, I would like you to fix this error in this update, good work.
