Hello, It seems possible at first glance to add 3 layers of steel to this structure. However, of course, in the end, as mentioned above, following the analyzes, reinforcement of the existing reinforced concrete structure and on the raft basis (for punching) may occur. First of all, a horizontal load-bearing system including steel columns whose support does not transfer moment and crosses between them can be considered in this region, so that the horizontal rigidity of the elevator and stair core shears will be continued upwards on the floors with the steel carrier system to be added. Since it will be very difficult to detail the supports of the columns, which will require the creation of chemical anchors and shear wedges, on the 20 cm thick wall, and also, it will be very difficult to carry the support tensile forces due to the earthquake load to the chemical anchors, it may be necessary to make a detailing with SPSW (steel plate wall) for this region. Steel columns located around the upper floor shears, which will be steel braced or steel plated, can be created by making chemical anchor detailing so that they do not transfer moment directly over the existing reinforced concrete columns. A steel-concrete composite flooring system should be considered for the floor slabs to be newly added. Since the steel sheared core is located in the middle of the structure, the effects of torsion need to be examined especially, and the precautions to be taken and the details to be made in the transfer of earthquake loads from the floors to the core are of great importance. A steel carrier system that is as light as possible and has a high energy absorption capacity should be constructed. It is possible to implement all these necessary models and analyzes by continuing on the current project with the current version of the ideStatik software, even including the SPSW system with the necessary idealizations. It is very important to carefully consider the relevant articles of the earthquake code for this type of structure (for the selection of the structural system response coefficients, the selection of the ductile level, the stages of applying earthquake loads and examining their effects, etc.). It would be healthy to detail the project after the preliminary evaluations and to continue with a professional service for the implementation afterwards. Best regards, Tolga Aydoner
