2005 update
alisenay
Greetings. I am a user of version 6.101. I want to talk about two problems. When I enter the first column sheathing house, the program closes itself automatically when I click to select the side to be jacketed, following the selection of the column to be jacketed. It only happens with this command and every time, I wonder what could be the reason. Secondly, after installing the program from the CD, when I run the program while connected to the internet, there is the 6.2005 version, a dialog box opens asking if you want to update it. It does not install. And when the next program is opened, it says there is 6.2005 version again. Do you want to update it? In short, although I downloaded the update file, I cannot install it. Thank you in advance for your reply. Greetings.
Hello. Although it is, it does not install the new version. And when you open the next program, it says there is a 6.2005 version and do you want to update it.[/quote] I think there may be two reasons why the 6.2005 version you downloaded could not be installed. 1. The entire program may not be downloaded. The size of the downloaded file should be 223 mb. If the downloaded file size is less, download the program again 2-There may be a problem in the Windows registry. To solve this problem, click the Run Line from the Windows Start Menu. Type regedit here and click OK. Open the Registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ under Delete the {40F202E4-52D2-49F1-A7E9-CA905097F104} line. Try reinstalling 6.2005. When I enter the
column sheathing house, following the selection of the column to be sheathed, when I click to select the side to be sheathed, the program closes itself automatically. It only happens in this command and every time, I wonder what could be the reason.
No such problem was encountered in the program. After updating 6.2005, try again. If the problem persists, add a sample project. Good work
Thank you for your answer. Since the program is in my notebook, I will have the opportunity to try it after work in the evening. I'll give feedback after I try it.
Unfortunately, the line you marked under the uninstall folder you mentioned is not visible. is there anything else i can do? In addition, the volume of the program is 203mb. It is the same as when downloaded. I do not think it will be downloaded incompletely. The problem is, the install doesn't start at all, let me start if it fails somewhere, ok but...
There is a possibility that there is a malicious file in your system, after scanning for antivirus, antispyware, perform a maintenance and repair on your registry, there are many programs for this, such as Registry Mechanic, Glary Utilities, Wise Registry Cleaner Pro, Auslogics BoostSpeed ... still If you cannot install it, you can restore it if you have taken an image of the disk on which the operating system is installed (norton ghost, acronis) with a program such as; otherwise, you can apply to the last resort, namely the format method. greetings.
alisenay"]Unfortunately, the line you marked under the uninstall folder you mentioned is not visible. Is there anything else I can do?
If your Windows is 64 bit HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\ It can be under Uninstall\ Or click the Find line from the Edit menu in the Registry dialog and type the first 8 characters of the folder name -40F202E4- here.
Greetings; Although I deleted the file you mentioned, I couldn't download the 2005 version. I can't make any sense. I'm working with win7 64bit. Could there be a conflict? Also, my problem with sheathing continues, tell me. Two types of jacketing can be done. Firstly, when you choose jacketing from the floating menu and then mark the column, a box asking for jacketing thickness opens. In this way, after I enter the value I want in the box, I press OK and the program gives an error and closes itself. As the second option, after defining the column, I select it and enter its properties, it works when I give the sheathing thickness from the sheathing tab. Have you ever had a problem like this?
Greetings again; I was able to change the location of the update I downloaded and install it, but the column jacketing problem still persists.
Mr. Levent; I don't experience the problem on a project basis, even when I try to make a jacket by entering a single column on a blank screen, the program closes itself. That is, there is no such thing as the water hangs in the project, it is working properly in another project. When I run the column sheathing command from the floating menu, it hangs and closes. I can't understand it, I don't know if it has something to do with my windows settings.
In the Program's Settings / General Settings Dialog, can you uncheck the -open GL Hardware Accelerator- and -3D Drawing mode-enable the lines, close the program and try again? If the problem is not solved, contact us by voice 224-220 67 17
