bro, sorry for the static section properties tab I could not find it. I would appreciate if you tell me where the tab is."Levent Özpak":kgtuuo7k" said:Hi, "Draw axes" line may be checked in the formwork plan section settings. Uncheck it and cut again. If the problem is not resolved, add the project file. Good work
Double-click the section line in the formwork plan window. The Static Section Properties dialog will open. Uncheck the "Draw Axes" line on the Section Tab and click OK. Delete the current segment. Select the section line and take the section again with the "create section" command from the right-click menu."ower":2cvucaxy" said:bro, sorry I couldn't find the static section properties tab. I'd appreciate it if you could tell me where the tab is."Levent Özpak":2cvucaxy" said:Hi, "Draw axes" line may be ticked in formwork plan section settings. Remove the mark and cut again. If the problem is not resolved, attach the project file. Good work
The menu that appears when I double-click the section in the heart plan window"Levent Özpak":3i2kmu53" said:Double click the section line in the formwork plan window. Static Section Properties dialog will open. Uncheck the "Draw Axes" line and click OK. Delete the existing section. Select the section line and take the section again with the "create section" command from the right-click menu."ower":3i2kmu53" said:bro, sorry I couldn't find the static section properties tab. I would appreciate it if you could tell me where the tab is."Levent Özpak":3i2kmu53" said:Hi, "Draw axes" line may be ticked in formwork plan section settings. Get it. If the problem is not solved, attach the project file. Good work
tmm very cool, I finally found it, thank you very much, I double click the section line instead of the section line :lol: Mr. Levent, thank you very much for solving my problem. Good work..."Levent Özpak":3ii7lfqh" said:You will double-click on the section line. If you contact us by phone, we will help. 0-224-220-67-17
