14fi14 in the colon application plan but 12 bars in the column
aramerproje
Hello friends. We see the column reinforcements as the minimum reinforcement determined by the program, by pressing the column tab in the reinforced concrete drawing menu. I increased those reinforcements 1 by 2 each. Then I pressed the reinforced concrete button at the bottom. When I get the column application plan, 14fi14 appears in the reinforcement name section, but when I look inside the column, there are 12 bars. The same is true for column vertical expansions, it says 12fi14 directly there. Thanks in advance to those who have responded to this topic.
Re: COLUMN APPLICATION PLAN
"aramerproje":juakkljf" said:
hi friends. We see the column reinforcements as the minimum reinforcement determined by the program when we press the column tab in the reinforced concrete pull-out menu. I increased those reinforcements by 1 by 2, then below I pressed the reinforced concrete button. When I received the column application plan, 14fi14 appears in the reinforcement name section, but when I look inside the column, there are 12 bars. The same situation is observed in the vertical expansion of the column, it says 12fi14 directly there. Thank you in advance to my friends who are interested in the subject and respond.
Hello, Longitudinal You need to arrange the reinforcements as an even number. If the problem is not fixed, add the project file. Good work
