Good afternoon, Only the deformation shape under vertical loading is as in the picture. The deformation decreases towards the lower floors. It's especially noticeable in the middle beams. The loads on the beams are the same. wall loads etc. Shouldn't the displacements on all floors be close to each other? As a result, loads proceed as slab-beam-column. each floor disintegrates within itself. Do you think this form of deformation makes sense? Or am I thinking wrong. Thanks in advance.
