While a texture can be assigned to the Plate of a created ribbed tile, the rib beams cannot be assigned because there is no menu. It stays in the default color.
Hello, When you select and change the material of your slab with the change surface texture command in the Visualization menu, your rib beams will change according to the slab. Take it easy, good work.
