Program hangs suddenly while analyzing
saliha esen
hello, it started to happen after installing a new version. The program suddenly closes while analyzing. what could be the problem? can you help me?
CAN YOU LOOK URGENTLY? THERE ARE SOME ERRORS IN THE PROJECT, I CAN'T FIX IT, AND I WOULD LOVE IF YOU LOOK AT IT BRIEFLY.
THANK YOU SO MUCH. SO CAN YOU TELL ME HOW YOU GOT IT SO MUCH IF I HAVE TO FACE THIS PROBLEM AGAIN, I WON'T DRESS YOU.
I HAVE ANALYSIS AGAIN NOW, IT SHALL CLOSE AGAIN. I HAVE FACED THE PROBLEM AGAIN. THERE IS NO DIFFICULT IN THE TWO GEOMETRY ANALYSIS.
Hello
"saliha eden":7qa9mkb4" said:
THE COLUMN BEAM CUTTING SAFETY FAULTS ARE ALSO ELIMINATED HOW DID YOU GET THEM?
I didn't do anything other than fix the colon. IT SWITCHES OFF. I CAME AGAIN WITH THE PROBLEM, NO DIFFICULTY IN THE TWO GEOMETRY ANALYSIS.[/quote] I made an account of the project I sent on two different computers by changing their names, and the shutdown problem did not occur. It may be from your computer. Screen result is below. Unver ÖZCAN
