After you place your horizontal floor plans, the images you provide as links belong to your horizontal floor plan presentations. You can create your furnished floor plans using the section command. You can access the following link ideCAD Architecture with Furnished Floor Plan Presentation"stability":24d414js" said:https://www.google.com/search?q=3%2B1+flat+plan%C4%B1&sxsrf=ALeKk03TDxMQ-3Qx4sA8lZ9z0SHL-pxPEg:1588082140496&source=lnms&t When you click the X&ved=2ahUKEwi4xe7-oovpAhUplIsKHdlQCOwQ_AUoAXoECAwQAw#imgrc=u6OBcyycilKdHM link, many projects come visually.How do I do this in idearchitecture?
Using the curtain command 2 method you can define. The first method;"istikrar":24d414js" said:how to define your subbasement?
I can do this. This time, the site name is written twice in the plan. So twice the action If it writes both the name and the area automatically when writing the places, why doesn't it put it into perspective. Secondly, yes, I know the add image option. I clicked the place with the Img sign ( ) but it does not want the file"sedaerdogan":1q7bd2gw" said:Hi, If you write the names of the places in 3D text, they will appear in perspective view and render. You can add them using the add image option.
