Hello, you can create the desired wall geometry in 3 dimensions with the Extended Object or Curtain Wall commands. To create with an extended object; - Create a continuous line section of your curved surface. - Select your drawing and turn it into an object with the extended object command. - Edit the jeans and thickness values and put them in place To create with curtain wall; - Build your curtain wall along your front. - Mark the border, horizontal and vertical registration types as absent from the settings of the curtain wall you have created. - Select your curtain wall with the Curved Curtain Wall command and enter the desired angle value. You can make the necessary arrangements about the plan in the 2D plane. For detailed information, you can call our Bursa office. Good work...
