garage project
Hello, There is no problem in terms of data entry in the project. In general, in terms of modeling and analysis settings, it is good to consider the following points; * Since the superstructure interactive solution is made in the project, it would be appropriate to design the basic system as a beamless raft. *It is recommended to model the panels as shells. *The ductility level was selected high in the Analysis Settings and R=4 was entered. In highly ductile systems with framed curtains, R=6-7 can be taken according to the alphaS condition. (R=6 can be taken as alfaX is close to 1 in this project.) *The minimum shrinkage rate of 0.0025 is entered in the raft laying parameters. This value can be taken as 0.0020. Note: As the project is a single storey, the situations mentioned above may not have an effect on the project results. Good work
