MustafaAkın20
Hello, while doing static modeling, I connect the beams according to the column mid axis as much as possible, but when I transfer the drawing as ifc, the beams seem to have entered the column and when transferring this image complexity to the architectural model, there is a problem when transferring it to Revit. If I connect the beams to the ends of the columns, will I have any problems in terms of calculation, so does the program define the link element to the column center again? Thanks in advance for your answer.
