CENTER
shewger
Hello, I'm adding dwg and ide in order, I couldn't define the marquise part, can you help? I want to show my heights on the balconies with parapets with curtains, but I couldn't adjust his jeans, I would appreciate it if you could help. I couldn't add the extension, I will send an ss and add the idecad extension alone
Hello, You can create the situation you want with the value you enter in the denim and top dent options in the curtain settings. You can use the extended object command to model the marquise. To get more detailed technical support for your project, you can call our Istanbul or Bursa office and get support via remote access. Take it easy, good work.
