Bim tools used in architectural design
HakanŞahin
Administrator
The commands used for the architectural design building information model (BIM) are given below in alphabetical order.
Click the link below to download the trial version and start working immediately.
CommandLocation of command in ribbon menu or toolbarExplanation
1
Tools/Import-Export/ImportImports 3D Block.
ideCAD logo/Import
2
Tools/Import-Export/ExportExports 3D Block.
ideCAD logo/Export
3
Tools/Import-Export/ExportExports to OBJ file format.
ideCAD logo/Export
4
Facade/RailingDraws 3D railing over objects.
5
Facade/RailingDraws 3D railing.
6
Rendering/3D Geometric ObjectsDraws 3d text.
7
Tools/Import-Export/ExportExports to 3DS file format.
ideCAD logo/Export
8
Tools/Import-Export/ImportImports 3DS file format.
ideCAD logo/Import
9
View/Workplane/Target WorkplaneCreates a workplane through 3 points.
10
Steel/Macro/Single Plate ConnectionCreates a 4 bolts unstiffened end plate connection.
11
Steel/Macro/Single Plate ConnectionCreates a 8 bolts stiffened end plate connection.
12About ideCAD ArchitecturalideCAD logo/HelpIt gives the program version and usage license information.
13
Home/SnapUses defined local coordinate system.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
14
Right click menu in perspective viewCreates snap points on a line in a perspective image.
15
It is located in the hatch toolbar.Adds lines to the hatch edges.
16
It is located in the hatch toolbar.Add a new point to hatch.
17
Home/Concrete/StairAdds stair area to an existing stair.
Concrete/Concrete/Stair
18
Right click menuAdds new objects to the groups
19
Modify/Entity Edit/DimensionAdds/removes dimension parents.
20
Home/EditGenerates array of entities.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
21
Home/SnapEnables advanced snap mode.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
22
Settings/Menu SettingsEdits commands used on the command line.
23
It is located in the align toolbar.Aligns the selected entities at the bottom.
24
It is located in the align toolbar.Aligns the selected entities by drawing a path.
25
It is located in the align toolbar.Align the selected entities by selecting an edge of entity.
26
Home/ModifyAligns the selected entities.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
27
It is located in the align toolbar.Aligns the selected entities to the left.
28
It is located in the align toolbar.Aligns the selected entities to the object center.
29
It is located in the align toolbar.Aligns the selected entities to the nearest point.
30
It is located in the align toolbar.Aligns the selected entities to the right.
31
It is located in the align toolbar.Aligns the selected entities to the top.
32
Home/ReferenceMeasures the angle.
Facade/Reference
Concrete/Reference
Steel/Reference
Tools/Reference
Drawings/Reference
33
Drawings/DimensionDraws angle dimension.
34
It is located in the library toolbar.Sets vertical angle of library automatically using underlying geometry.
35
Steel/Macro/Single Plate ConnectionCreates a apex type connection.
36
It is located in the primitives toolbar.Draws arc.
37
Home/AxisDraws arc axis.
Concrete/Axis
Steel/Axis
38
Home/AxisDraws arc axis through 3 points.
Concrete/Axis
Steel/Axis
39
Concrete/ConcreteDraws arc beam.
40
Home/Roof/DomeDraws arc dome.
41
Home/Roof/DomeDraws arc dome through 3 points.
42
Concrete/Concrete/Slab EdgeDraws arc slab edge.
43
It is located in the primitives toolbar.Draws arc through 3 points.
44
It is located in the wall toolbar.Draws arc wall.
45
It is located in the zone edge toolbar.Draws arc zone edge.
46
Home/ReferenceCalculates area.
Facade/Reference
Concrete/Reference
Steel/Reference
Tools/Reference
Drawings/Reference
47
Home/EditGenerates an array of entities.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
48
Rendering/RenderContinously assigns selected material to face groups.
49
Modify/Entity EditAuto label entities.
Tools/Tools
50
It is located in the hatch toolbar.Creates hatch with closed polygons.
51
Home/AxisDraws axis.
Concrete/Axis
Steel/Axis
52
Modify/Entity Edit/Move Axis LabelSets the axis border.
53
It is located in the axis toolbar.Draws an axis with an offset to the previous axis drawn.
54
Home/Axis/AxisOpens axis settings.
Concrete/Axis/Axis
Steel/Axis/Axis
55
View/PerspectiveChanges view to axonometric.
56
View/PerspectiveChanges view to back.
57
View/ViewOpens background settings.
58
It is located in the sweep toolbar.Draws baseboard.
59
Concrete/ConcreteDraws multiple beams.
60
Concrete/Concrete/BeamOpens beam settings.
61
Modify/TransformConverts beams to shearwalls.
62
Facade/Exterior Facade/Curtain WallBends curtain wall.
63
Drawings/Primitives/NURBSDraws bezier curve.
64
Drawings/HatchDraws bitmap hatch.
65
Steel/Macro/Single Plate ConnectionCreates a bolted flange plate connection.
66
It is located in the sweep toolbar.Draws border on wall.
67
Home/Roof/VaultDraws border vault.
68
View/PerspectiveChanges view to bottom.
69
Home/Entities/3D ObjectsDraws box.
Facade/3D Geometric Objects/3D Objects
70
Steel/Macro/Single Plate ConnectionCreates box/tube cap plate.
71
Steel/Macro/Single Plate ConnectionCreates a box/tube end plate connection.
72
Steel/Macro/Single Plate ConnectionCreates a box/tube seating connection.
73
Steel/Macro/Single Plate ConnectionCreates a box/tube splice connection.
74
Steel/Macro/Single Plate ConnectionCreates a brace center connection(9).
75
Steel/Macro/Single Plate ConnectionCreates a brace corner connection(10).
76
Home/ModifyBreaks off a certain part of the objects.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
77
Tools/BUA/FAR ReportsCreates GRZ/GFZ report.
78
Home/Axis/AxisCalculates contour polygon.
Concrete/Axis/Axis
Steel/Axis/Axis
79
Rendering/Lights-CameraDraws camera.
80
Rendering/RenderCreates camera animaton.
81
Rendering/RenderDraws camera path.
82
Rendering/Lights-Camera/CameraOpens camera settings.
83
Modify/Entity Edit/StairCancels secondary stair deformation.
84
Modify/Entity Edit/StairCancels stair deformations.
85
It is located in the sweep toolbar.Draws cartonpierre.
86
It is located in the column toolbar.Sets center aligned.
87
It is located in the single footing toolbar.Sets centered single footing.
88
Home/ModifyConnects two lines with a third line.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
89
Home/AxisChanges axis drawing type.
Concrete/Axis
Steel/Axis
90
Home/Concrete/StairChanges baluster count.
91
Modify/Entity Edit/ColumnChanges column dimensions.
92
It is located in the ODT door/window toolbar.Change dio distance point.
93
Modify/Entity Edit/SweepChange edge part end angles.
94
Modify/LayersChanges layers of selected entities.
95
It is located in the jamb toolbar.Changes jamb placement to the other side of dio.
96
Home/Roof/RoofChanges rafter dimensions.
Modify/Entity Edit/Roof
97
Home/Roof/Roof DetailsChanges roof edge properties.
98
Home/Concrete/ShearwallChanges shearwall length.
99
It is located in the railing toolbar.Changes path direction.
It is located in the curtain wall toolbar.
100
Tools/ToolsChecks validity of project geometry.
101
Drawings/PrimitivesDraws circle.
102
Concrete/Concrete/BeamDraws circle beam.
103
Concrete/Concrete Slab EdgeDraws circle slab edge.
104
It is located in the wall toolbar.Draws circle walls.
105
It is located in the zone edge toolbar.Draws circle zone edge.
106
Home/Concrete/ColumnDraws circular column.
Concrete/Concrete
107
Home/EditClones (immediately copies) objects.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
108CloseideCAD logoCloses current project.
109
Drawings/Primitives/NURBSDraws closed bezier curve.
110
Drawings/Primitives/NURBSDraws closed NURBS curve.
111
Modify/Transform/Beam to ShearwallTransforms primitive entities to polygon column.
112
Modify/Transform/Beam to ShearwallTransforms primitive entities to polygon section.
113
Home/Roof/Roof DetailsDraws a collar beam.
114
Home/ConcreteDraws rectangular column.
Concrete/Concrete
115
Home/Concrete/ColumnOpens column settings.
Concrete/Concrete/Column
116
Home/Concrete/ColumnDraws column support.
Concrete/Concrete
117
Steel/Macro/Single Plate ConnectionCreates a column-beam stiffened end plate connection.
118
Steel/Macro/Single Plate ConnectionCreates a built up column connection.
119
Steel/Macro/Single Plate ConnectionCreates a column-column end plate splice connection.
120
Steel/Macro/Single Plate ConnectionCreates a column-foundation connection (Stiffened baseplate).
121
Tools/Quantity ReportCreates components report.
122
Settings/Element MaterialsConstructs and arranges composite materials.
123
Steel/SteelDraws composite slab.
124
Steel/Steel/Composite SlabDraws composite solid slab.
125
Steel/Steel/Composite SlabDraws concrete slab over steel beams.
126
It is located in the tubes toolbar.Draws cone-pyramid.
127ContentsideCAD logo/HelpOpens the program's help document.
128
Concrete/ConcreteDraws continuous arc beams.
129
Home/WallDraws continuous arc walls.
130
Steel/Macro/Single Plate ConnectionCreates a continuous beam connection.
131
Concrete/Concrete/Slab EdgeDraws continuous slab edges.
132
It is located in the zone edge toolbar.Draws continuous zone edges.
133
Home/Axis/AxisSets contours of the drawing.
Concrete/Axis/Axis
Steel/Axis/Axis
134
Home/EditCopies entities.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
135
Tools/EditCopies contours of a drawing.
136
Tools/File SharingCopies entities to a .blk file.
137
Facade/3D Geometric ObjectsDraws cordon.
138
Facade/3D Geometric Objects/CordonOpens cordon settings.
139
It is located in the column toolbar.Sets corner aligned column.
140
It is located in the single footing toolbar.Sets corner aligned single footing.
141
Steel/MacroDraws crane.
142
Steel/Macro/Single Plate ConnectionCreates a crane connection.
143
Right click menu in the perspective viewCreates camera.
144
View/WorkplaneCreates a clip plane.
145
Drawings/Layout DesignCreates a new layout window.
146
Right click menuCreates new selection groups.
147
Home/Concrete/StairCreates a new stair.
148
It is located in the hatch toolbar.Creates user defined hatch from block objects.
149
Facade/Exterior FacadeDraws curtain wall.
150
Facade/Exterior Facade/Curtain WallDraws curtain wall dio.
151
Facade/Exterior Facade/Curtain WallOpens curtain wall settings.
152
Concrete/ConcreteDraws curve beam.
153
Concrete/Concrete/Slab EdgeDraws curve slab edge.
154
Home/WallDraws curve wall.
155
It is located in the zone edge toolbar.Draws curve zone edge.
156
Modify/Transform/Beam to ShearwallConverts circle, arc, ellipse objects to beam.
157
Modify/Transform/Beam to ShearwallConverts circle, arc, ellipse objects to shearwall.
158
It is located in the tubes toolbar.Draws cylinder.
159
Tools/Quantity ReportCreates DIN277 report.
160
Tools/Import-Export/ImportImports DWG DXF file formats.
161
Tools/Import-Export/ExportExports to DWG DXF DWF file formats.
162
163
It is located in the column toolbar.Sets default aligned.
164
It is located in the single footing toolbar.Sets default single footing.
165
Home/SnapDefines temporary coordinate system origin.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
166
Modify/Entity Edit/SweepDefines end cut to edge.
167
Modify/Entity Edit/SweepDefines inner cut to edge.
168
Modify/Entity Edit/SweepDefines local offset to edge.
169
Modify/Entity Edit/SweepDefines offset to edge.
170
Home/Concrete/StairDeforms stair.
171
Home/EditDelete entities.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
172
It is located in the horizontal plan section toolbar.Deletes horizonal plan section.
173
It is located in the mirror toolbar.Delete old entities on mirror.
174
It is located in the pool toolbar.Delete primitives after pool creation.
175
Home/Roof/Roof DetailsDeletes roof element(s).
176
It is located in the slab for steels toolbar.Deletes slab hole.
177
It is located in the wall toolbar.Changes delta value.
It is located in the beam toolbar.
It is located in the shearwall toolbar.
It is located in the strip footing toolbar.
178
Home/EditDeselects all entities.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
179
Tools/Quantity ReportDesign components.
180
Rendering/Lights-CameraDraws directional light.
181
Rendering/Lights-Camera/Directional LightDirectional light settings.
182
View/WorkplaneDisplay a vertical frame.
183
Home/ReferenceCalculates distance.
Facade/Reference
Concrete/Reference
Steel/Reference
Tools/Reference
Drawings/Reference
184
It is located in the distribute toolbar.Distribute by drawing a path.
185
It is located in the distribute toolbar.Distribute by selecting an edge of entity.
186
Home/ModifyDistrubutes the selected entities.
187
It is located in the distribute toolbar.Distrubutes selected entities to the horizontally.
188
It is located in the distribute toolbar.Distribute selected entities to the object center.
189
It is located in the distribute toolbar.Distribute selected entities to the nearest point.
190
It is located in the distribute toolbar.Distrubute selected entities to the vertically.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
191
Home/ModifyDivides the objects to the desired number.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
192
Steel/Steel/Steel PurlinDivides and combines on all intersections.
193
Steel/Steel/Steel PurlinDivides and combines on selected intersections.
194
Facade/3D Geometric ObjectDraws dome gutter.
195
Facade/3D Geometric Object/Dome GutterOpens dome gutter settings.
196
Home/Roof/DomeOpens dome settings.
197
Home/Door-Window/Door-WindowOpens door/Window settings.
Facade/Door-Window/Door-Window
198
Home/Door-WindowDraws Door/Window.
Facade/Door-Window
199
Home/RoofDraws dormer.
200
Home/Door-WindowDraws dormer window.
Home/Roof/Dormer
Facade/Door-Window
201
Home/Roof/DormerOpens dormer settings.
202
Steel/Macro/Single Plate ConnectionCreates a double angle connection.
203
Steel/Macro/Single Plate ConnectionCreates a double plate seating connection.
204
Steel/Macro/TrussDraws Double Vault Truss.
205
Tools/ToolsEnters drafting mode.
206
View/ViewDraw line weights.
207
Steel/MacroDraws connection in fast mode.
208
Right click menuDraws similar entity of the selected one.
209
It is located in the steel brace toolbar.Draws single steel brace.
210
It is located in the slab for steels toolbar.Draws slab hole.
211
It is located in the steel brace toolbar.Draws steel brace elements.
212
It is located in the steel brace toolbar.Draws steel brace with multiple steel elements.
213
View/WindowDisplay drawing list.
Drawings/Window
214
View/WindowArrange drawings in the project.
215
Home/Door-WindowDraws curtain wall dio.
216
Steel/Macro/Single Plate ConnectionCreates a eaves haunch connection.
217
It is located in the single footing toolbar.Sets edge aligned single footing.
218
Facade/Exterior Facade/Curtain WallEdits curtain wall item.
219
Modify/Entity Edit/DimensionEdit label text.
220
Rendering/RenderEdits material of an object.
221
Home/Entities/RailingEdits railing elevations.
Facade/Railing/Railing
222
It is located in the slab for steels toolbar.Edit slab edge.
223
Modify/Entity Edit/StairEdit stair.
224
Rendering/RenderEdits surface mapping parameters.
225
Modify/Entity EditEdit text.
Drawings/Text
226
Modify/Entity Edit/WallEdit walls.
227
Home/Terrain/Terrain PolygonDraws elevation line for terrain.
228
Drawings/ToolsDraws elevation line for elevation.
229
Drawings/Tools/Elevation LineElevation line settings.
230
Home/Terrain/Terrain PolygonDraws elevation point.
231
Drawings/Primitives/Ellipse CornersDraws ellipse using center and corner.
232
Drawings/PrimitivesDraws ellipse using corner.
233
Drawings/Primitives/Ellipse CornersDraws ellipse using midpoint and axis.
234
Drawings/Primitives/Ellipse CornersDraws elliptical arc using center and corner.
235
Drawings/Primitives/Ellipse CornersDraws elliptical arc using corners.
236
Drawings/Primitives/Ellipse CornersDraws elliptical arc using midpoint and axis.
237
Steel/Macro/Single Plate ConnectionCreates an end plate shear connection.
238
Steel/Macro/Single Plate ConnectionCreates an end plate truss connection.
239
Steel/Macro/Single Plate ConnectionCreates an end plate truss connection for box/tube.
240
KeyboardRuns the command. It has functions in various command stages.
241
Tools/GenerateEntity from primitives.
242
Home/ModifyChanges entity properties.
Facade/Modify
Concrete/Modify
Steel/Modify
Modify/Entities
Drawings/Modify
243
KeyboardExits the found command.
244
It is located in the single footing toolbar.Exchange coordinates.
245ExitideCAD logoQuits the application.
246
Home/ModifySeparates the blocks into sub-blocks.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
247
Modify/Entity Edit/RoofExplodes roof.
248
It is located in the steel beam toolbar.Explodes and groups multi-element entities into single elements.
It is located in the steel purlin toolbar.
249
Tools/Quantity Report/ExportExports components as a database file To AMP.
250
Tools/Quantity Report/ExportExports components as a database file To OSKA.
251Export to ideRENDERRendering/ToolsExports your drawing to ideRENDER.
252
Home/ModifyLine extends primitive objects such as arcs to another line or arc.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
253
Facade/Exterior FacadeDraws exterior veneer.
254
Facade/Exterior Facade/Exterior VeneerExterior veneer settings.
255
Home/Entities/3D ObjectsDraws extruded object.
256
Home/Roof/Roof DetailsDraws fascia boards.
257
Home/ModifyActivates fast move.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
258
Home/ModifyIt connects two lines with an arc.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
259
Tools/ToolsFinds entities based on their labels.
260
It is located in the hatch toolbar.Finds hatch holes.
261
Right click menu in perspective viewFinds the selected object which is in the plan window, in the perspective window and zooms the view to that object.
262
Right click menu in plan viewFinds the selected object which is in the perspective window, in the plan window and zooms the view to that object.
263
Steel/Macro/Single Plate ConnectionCreates a flange plate connection.
264
Steel/Macro/TrussDraws Flat Truss.
265
Right click menu in perspective viewOpens fly mode.
266
Drawings/TextDraws formatted text.
267
Drawings/DimensionDraws free dimension.
268
It is located in the sweep toolbar.Sets free drawn.
269
Drawings/PrimitivesDraws freehand curve.
270
Concrete/Concrete/SlabCreates a free mode slab by selecting boundary entities manually.
271
Home/Zone/ZoneCreates a free mode zone by selecting boundary entities manually.
272
View/PerspectiveChanges view to front.
273
Facade/3D Geometric ObjectSweep settings.
274
Tools/GenerateGenerates a 2D simple drawing using current drawing.
Drawings/Tools
275
Tools/GenerateGenerates vector drawing.
Rendering/Tools
276
It is located in the terrain toolbar.Get elevation from terrain.
277
Home/ModifyPicks settings from entity.
Facade/Modify
Concrete/Modify
Steel/Modify
Modify/Entities
Drawings/Modify
278
Tools/Selection GroupsGets currently selected entities.
279
Steel/Macro/Single Plate ConnectionCreates a girt connection.
280
View/ViewGrid & limits settings.
281
Tools/Selection GroupsGroups selected entities and selects entities based on these groups.
282
Drawings/HatchDraws hatch hole.
283
Drawings/Hatch/User Defined HatchHatch settings.
284
Steel/Macro/Single Plate ConnectionCreates a haunch connection.
285
View/View/Solid with EdgesChanges view detail to hidden line.
286
View/ViewChanges view detail to hidden line black && white.
287
Modify/Entity Edit/SweepHides/shows edge.
288
Modify/Entity Edit/SweepHides/shows edge part.
289
Home/Roof/Roof DetailsDraws hip/valley rafters.
290
Home/TerrainDraws hole.
291
Rendering/ToolsOpens horizontal plan section toolbar.
292
View/Workplane/Target WorkplaneCreates a horizontal workplane.
293
Tools/Import-Export/ImportImports IFC file. Merges file content with current project.
ideCAD logo/Import
294
Tools/Import-Export/ExportExports project to IFC.
ideCAD logo/Export
295
Tools/Quantity ReportCreates II BV report.
296
Drawings/TextImports text from a text file.
297
Right click menu/Drawing orderSends the selected object to the background.
298
Right click menu/Drawing orderSends the selected object behind a certain object.
299
Right click menu/Drawing orderSends the selected object to the foreground.
300
Right click menu/Drawing orderSends the selected object in front of a certain object.
301
Modify/Entity EditIncline objects.
302
It is located in the dimension toolbar.Includes beams into section dimension.
303
It is located in the dimension toolbar.Includes doors/windows into section dimension.
304
It is located in the dimension toolbar.Includes slabs into section dimension.
305
Drawings/DimensionsDraws inner dimension.
306
Settings/Project SettingsOpens input units.
307
Drawings/Layout Design/Create New LayoutInserts a layout block.
308
Home/Concrete/StairChanges insertion point.
It is located in the stair toolbar.
309
Drawings/DimensionsDraws intersection dimension.
310
Home/EditInverts current selection.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
311ideCAD HomeideCAD logoOpens the start page.
312
Home/Door-Window/Door-WindowDraws jamb.
313
Facade/Exterior Veneer/JambOpens jamb settings.
314
Home/ModifyJoins linear objects.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
315
Steel/Macro/Single Plate ConnectionCreates a beam-beam connection (Joining plates).
316
Coordinate BoxL enters the coordinate box. Object length is entered.
317
Drawings/DimensionDraws label.
318
Modify/Entity EditLabel entities.
319
It is located in the exterior veneer toolbar.Draws lap siding.
320
It is located in the exterior veneer toolbar.Draws lap siding with gap.
321
Home/EditSelects last selected entities.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
322
Home/Roof/Roof DetailsDraws laths.
323
Settings/Element PropertiesOpens layer settings.
324
Drawings/Layout Design/Create New LayoutChanges settings of current layout.
325
View/PerspectiveChanges view to left.
326
It is located in the column toolbar.Sets edge left middle aligned.
327
It is located in the dimension toolbar.Left side section dimension.
328
Drawings/DimensionDraws level dimension.
329
Home/EntitiesDraws library.
Drawings/Primitives
330
Home/Entities/LibraryDraws library settings.
Rendering/3D Geometric Objects/Library
Drawings/Primitives/Library
331
Settings/Project SettingsLoads settings from a file.
332
Tools/EditLocal undo, undo for current mode only.
333
Modify/LayersLocks/Unlocks layers.
334
Home/ModifyBlocks entities.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
335
Tools/EditMake architectural file compatible with structural.
336
Settings/Element PropertiesMaterials are listed, edited, created.
Rendering/Render
337
Settings/Menu SettingsOpens menu settings.
338
Steel/Steel/Composite SlabDraws metal slab.
339
Home/SnapSnaps to midpoints of entities.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
340
Home/ModifyTakes symmetry.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
341
It is located in the ODT door/window toolbar.Mirrors door/window labels.
342
It is located in the ODT door/window toolbar.Takes symmetry with respect to the X-axis.
343
Home/Concrete/StairTakes symmetry with respect to the Y-axis.
344
It is located in the trusses toolbar.Allow modify sub elements of truss.
345
Home/ModifyMove.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
346
Home/Axis/AxisMoves axis label.
Concrete/Axis/Axis
Steel/Axis/Axis
Modift/Entity Edit
347
Modify/Entity Edit/DimensionMoves dimension texts.
348
It is located in the raft foundation toolbar.Moves raft foundation text.
349
Modify/Entity Edit/SlabMoves slab text.
350
Modify/Entity Edit/ZoneMoves zone text.
351
Steel/Macro/Single Plate ConnectionCreates multi stiffener plates.
352
Steel/Macro/Single Plate ConnectionCreates horizontal multi stiffener plates.
353
Drawings/PrimitivesDraws multiple lines.
354
Home/SnapSnaps to nearest points of entities.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
355
ideCAD logoOpens the new project open dialog.
356
ideCAD logoCreates a new, empty 2D drawing window.
357
It is located in the horizontal plan section toolbar.Adds new horizontal plan sections.
358
ideCAD logoCreates a new project.
359
Drawings/Layout Design/Create New LayoutCreates a new layout block using all drawing.
360
361
362
363
364
View/WindowActivates next window.
365
View/NodesOpens node settings.
366
Steel/Macro/Single Plate ConnectionCreates a notched seating connection.
367
Drawings/PrimitivesDraws NURBS curve.
367
Home/ModifyOffset.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
368
It is located in the section toolbar.Finishes the current job.
369
ideCAD logoOpens a previously saved project.
370
Home/SnapEnters orthogonal drawing mode.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
371
Drawings/DimensionsDraws outer dimension.
372
KeyboardScrolls down the page in reports. Also shifts the viewpoint down in fly mode in the perspective view.
373
KeyboardScrolls the page up in reports. Also shifts the viewpoint upwards in flight mode in the perspective view.
374
View/ZoomPans the window.
375
Home/SnapParallel reference.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
376
Home/EditPaste entities.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
377
Drawings/PrimitivesDraws path primitives.
378
It is located in the sweep toolbar.Sets path based.
379
Drawings/PrimitivesDraws pattern path.
380
Drawings/HatchDraws parametric hatch.
381
It is located in the sweep toolbar.Sets parent based.
382
Tools/EditPastes contours.
383
Tools/File SharingPastes entities from a .blk file.
384
Tools/Import-Export/ExportExports To PDF.
ideCAD logo/Export
385
Settings/Element PropertiesOpens pen and color settings.
386
Home/SnapPerpendicular reference.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
387
View/PerspectiveChanges view to perspective.
388
Rendering/Lights-CameraDraws photometric light.
389
Rendering/Lights-Camera/Photometric LightPhotometric light settings.
390
Tools/Import-Export/ExportSaves the screen image as a bitmap file.
ideCAD logo/Export
391
Rendering/RenderCreates Planar Texutre Mapper Object.
392
Home/TerrainDraws plateau.
393
ideCAD logoPlots your drawings.
394
Rendering/Lights-CameraDraws point light.
395
Rendering/Lights-Camera/Point LightPoint light settings.
396
Home/EditCreates copies of objects with rotation.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
397
Settings/Project SettingsPolar tracking.
398
Home/Concrete/ColumnDraws polygon column.
Concrete/Concrete
399
Modify/Transform/Beam to ShearwallTransforms primitive entities to plate section.
400
Steel/Steel/SheetingDraws sheeting polygon.
401
Home/EntitiesDraws pool.
402
Home/Entities/PoolOpens pool settings.
403
Home/Roof/Roof DetailsDraws a post.
404
Home/Project SettingsOpens preferences.
405
View/WindowActivates previous window.
406
Settings/Element PropertiesOpens profiles
407
Settings/Project SettingsOpen project settings.
408
Settings/Project SettingsOpen project save settings.
409
Home/Project SettingsOpens project settings.
Concrete/Project Settings
Steel/Project Settings
410
Home/Roof/Roof DetailsDraws purlins.
411
Steel/Macro/Single Plate ConnectionCreates a purlin connection.
412
Tools/Quantity ReportGenerates a report of quantities in the project.
413
Steel/Steel/Steel PurlinDraws R purlin.
414
Drawings/DimensionDraws radius dimension.
415
Concrete/FoundationDraws raft foundation.
416
Concrete/FoundationDraws raft edge.
417
Concrete/Foundation/Raft EdgeOpens raft edge settings.
418
Concrete/Foundation/RaftDraws raft foundation hole.
419
Concrete/Foundation/RaftOpens raft foundation settings.
420
Home/Roof/Roof DetailsDraws rafters.
421
Home/EntitiesDraws railing.
Facade/Railing
422
Home/Entities/RailingDraws 3D railing.
423
Home/Entities/RailingDraws 3D railing over objects.
424
Home/Entities/RailingOpens railing settings.
FacadeRailing/Railing
425
Home/RoofDraws rainwater pipe.
426
Home/Roof/Rainwater PipeOpens rainwater pipe settings.
427
Drawings/PrimitivesPlaces a raster image file onto the drawing.
428
Rendering/RenderRecalls render with the last settings.
429
Drawings/Primitives/Multiple LinesDraws a rectangle.
430
Home/WallDraws 4walls as a rectangle.
431
Tools/EditRedo.
432
Modify/Entity Edit/SweepRemoves end cut of edge.
433
Right click menuRemoves objects from the group.
434
Modify/Entity Edit/SweepRemoves inner cut of edge.
435
Modify/Entity Edit/SweepRemoves local offset of edge.
436
It is located in the space truss toolbar.Removes a nodule from space truss.
437
Modify/Entity Edit/SweepRemoves offset of edge.
438
It is located in the hatch toolbar.Removes an existing point on the hatch.
439
Rendering/RenderRenders active view.
440
Right click menuRepeats last command.
441
Modify/Entity Edit/DimensionResets dimension text displacements.
442
Settings/Project SettingsResets settings.
443
Drawings/PrimitivesDraws revision cloud.
444
Home/Entities/3D ObjectsDraws revolved object.
445
View/PerspectiveChanges view to right.
446
It is located in the dimension toolbar.Right side section dimension.
447
Steel/Macro/Single Plate ConnectionCreates a rigid on both axis base plate connection.
448
Steel/Macro/Single Plate ConnectionCreates a rigid on strong axis base plate connection.
449
Home/RoofDraws roof.
Modify/Entity Edit
450
It is located in the roof toolbar.Opens the roof details toolbar.
451
Facade/3D Geometric ObjectDraws roof gutter.
452
Facade/3D Geometric Object/Roof GutterOpens roof gutter settings.
453
Home/Roof/RoofDraws roof hole.
454
Home/Roof/RoofDraws roof plane.
455
Home/Roof/RoofOpens roof settings.
456
Home/Door-WindowDraws roof window.
Home/Roof/Roof
Facade/Door-Window
457
Home/ModifyRotate.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
458
Home/ModifyRotates the building.
Facade/Modify
Concrete/Modify
Steel/Modify
Tools/Tools
Drawings/Modify
459
Facade/Exterior Veneer/Curtain WallRotates curtain wall panel.
460
Home/ModifyRotates node.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
461
Steel/Macro/Single Plate ConnectionCreates a round plate tube base plate connection.
462
ideCAD logoSaves current project.
463
ideCAD logoSave current project with a new name.
464
ideCAD logoSaves compresed project file.
465
ideCAD logoSaves old version project file.
466
Settings/Project SettingsSaves settings to a file.
467
Home/Concrete/StairSaves stair.
468
Home/ModifyScales entities.
Concrete/Modify
Steel/Modify
Drawings/Modify
469
Home/ModifyScales entities by referance.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
470
Steel/Macro/Single Plate ConnectionCreates a seating support connection(8).
471
Steel/Macro/Single Plate ConnectionCreates a seating truss connection.
472
Steel/Macro/Single Plate ConnectionCreates a seating weld connection.
473
Modify/Entity Edit/StairSecondary stair deformation.
474
Steel/SteelDraws secondary beam.
475
Tools/GenerateEdit and generate sections and elevations.
Drawings/ToolsEdit and generate sections and elevations.
476
It is located in the dimension toolbar.Draws single section dimension.
477
It is located in the dimension toolbar.Draws section dimension group.
478
Drawings/DimensionDraws section elevation.
479
Drawings/ToolsOpens section elevation settings.
480
Drawings/ToolsDraws section line.
481
Drawings/Tools/Section LineOpens section line settings.
482
Home/EditSelects all entitites.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
483
Steel/Steel/Steel PurlinSelect purlins to add analysis.
484
Home/EditSelects entity in all stories.
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
485
Right click menuSelect the objects in the group.
486
It is located in the terrain toolbar.Selects terrain and child entities.
487
It is located in the library toolbar.Set auto elevation.
488
Home/ModifySets default settings to selected entities.
Facade/Modify
Concrete/Modify
Steel/Modify
Modify/Entities
Drawings/Modify
489
Modify/Entity EditSets hatch reference point.
490
Home/SnapSets new local coordinate system.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
491
Home/Entities/PoolSet pool cantilever slab properties.
Modify/Entity Edit/Pool
492
Home/Entities/PoolSet pool surface properties.
493
Home/Entities/PoolSet pool surface slope.
494
Home/Entities/PoolSet pool wall properties.
495
Tools/Selection GroupsSets currently selected entities.
496
Concrete/Concrete/StairSets boundary conditions of stairs.
497
It is located in the steel column toolbar.Sets steel element delta.
498
Modify/Entity EditSets entity trim algorithm.
499
Modify/Entity EditSets priorities of wall at joints.
500
Home/ConcreteDraws shearwall.
Concrete/Concrete
501
Home/Concrete/ShearwallOpens shearwall settings.
Concrete/Concrete/Shearwall
502
Modify/Transform/Beam to ShearwallConverts shearwalls to beams.
503
Steel/SteelDraws sheeting over purlins.
504
Steel/Steel/SheetingDraws sheeting between two elements.
505
View/ViewShow coordinate box.
506
Right click menu in the perspective view.Shows the render boundaries before rendering.
507
View/ViewShow toolbars.
508
Modify/Entity Edit/DimensionShows/hides dimension text.
509
Modify/LayersShow/hide entity layers.
510
View/NodesShows/hides nodes
511
Home/Concrete/StairShows/hides railings.
512
Steel/Macro/Single Plate ConnectionCreates a simple base plate connection.
513
Concrete/FoundationDraws single footing.
514
Steel/Macro/Single Plate ConnectionCreates a single angle connection.
515
Concrete/Foundation/SingleOpens single footing settings.
516
Steel/Macro/Single Plate ConnectionCreates a single plate connection.
517
Steel/Macro/Single Plate ConnectionCreates a single plate seating connection.
518
Steel/Steel/Steel PurlinDraws single steel purlin.
519
It is located in the steel beam toolbar.Draws single secondary beam.
520
Concrete/ConcreteDraws slab.
521
Concrete/ConcreteDraws slab edge.
522
Concrete/Concrete/Slab EdgeOpens slab edge settings.
523
Concrete/Concrete/SlabDraws slab hole.
524
Concrete/Concrete/SlabOpens slab settings.
525
Steel/Macro/TrussDraws Sloping Flat Truss.
526
Steel/Macro/TrussDraws Sloping Vault Truss.
527
Home/SnapSnap to grid.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
528
Home/SnapSnap to nodes.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
529
View/ViewChanges view detail to solid.
530
View/ViewChanges view detail to solid with edges.
531
KeyboardMoves the cursor to horizontal, vertical, and free axis drawing positions on axes. Changes the offset in commands such as wall, column, beam, shearwall. Skips a name in object labeling. Changes the insertion point in commands such as stair, library.
532
Steel/Steel/Steel PurlinDraws space purlin.
533
Steel/MacroDraws space truss.
534
Steel/Macro/Single Plate ConnectionCreates a spacer plate connection.
535
Home/Entities/3D ObjectsDraws sphere.
536
Steel/Macro/Single Plate ConnectionCreates a splice connection.
537
Rendering/Lights-CameraDraws spotlight.
538
Rendering/Lights-Camera/Spot LightOpens spot light settings.
539
Home/ConcreteDraws stair.
Concrete/Concrete
540
Home/Concrete/StairOpens stair settings.
541
Steel/Macro/Single Plate ConnectionCreates a stay connection.
542
Steel/Macro/Single Plate ConnectionCraetes a stay connection (secondary beam).
543
Steel/SteelDraws steel beam.
544
Steel/SteelDraws steel brace.
545
Steel/SteelDraws steel column.
546
It is located in th steel column toolbar.Draws steel column.
547
Steel/SteelDraws steel purlin.
548
Steel/Steel/Steel PurlinDraws steel tie.
549
Steel/Macro/Single Plate ConnectionCreates a stiffened end plate connection.
550
Steel/Macro/Single Plate ConnectionCreates a stiffened shear plate connection.
551
Settings/Project SettingsArrange stories in the project.
552
It is located in the sweep toolbar.Sets story alignment free.
553
It is located in the sweep toolbar.Sets story bottom aligned.
554
Home/Project SettingsCopies all entities from a story to another story.
Tools/Edit
555
Home/Project SettingsOpens story list.
View/Window
Drawings/Window
556
Home/Project SettingsArrange stories in the project.
557
It is located in the sweep toolbar.Sets story top aligned.
558
Home/ModifyStretch node.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
559
Concrete/FoundationDraws multiple strip footings.
560
Concrete/Foundation/StripOpens strip footing settings.
561
View/ModeEnters structural design mode.
562
Home/Roof/Roof DetailsDraws a strut.
563
Steel/Macro/Single Plate ConnectionCreates stub.
564
Home/TerrainDraws sub region.
565
It is located in the exterior veneer toolbar.Swaps side.
566
Home/Entities/3D ObjectsDraws sweep.
Modify/Entity Edit
567
It is located in the sweep toolbar.Opens the sweep operations toolbar.
568
Drawings/WindowReturns to last story window.
569
Steel/Macro/Single Plate ConnectionCreates a T plate connection.
570
Home/SnapDraws tangents.
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
571
View/WorkplaneCreates a free workplane using existing objects.
572
It is located in the exterior veneer toolbar.Draws terra cotta siding.
573
Home/TerrainDraws terrain polygon.
574
Home/Terrain/Terrain PolygonOpens terrain settings.
575
Rendering/3D Geometric Objects/3D TextDraws text.
Drawings/Text
576
Rendering/3D Geometric Objects/3D TextOpens font settings.
Drawings/Text/Text
577Tip of the DayideCAD logo/HelpShows tip of the day.
578
View/WindowResizes the view to full screen.
579
580
Concrete/Concrete/SlabTransforms a slab to a ribbed slab.
581
Concrete/Concrete/SlabTransforms a slab to a waffle slab.
582
View/ViewOpens transparent story settings dialog.
583
Steel/Macro/TrussDraws Trapezoid Sloping Left Truss.
584
Steel/Macro/TrussDraws Trapezoid Sloping Right Truss.
585
Steel/Macro/TrussDraws Trapezoid Sloping Symmetric Truss.
586
Steel/Macro/TrussDraws Trapezoid Slopping Asymmetric Truss.
587
Steel/Macro/TrussDraws Trapezoid Type 1 Truss.
588
Steel/Macro/TrussDraws Trapezoid Type 2 Truss.
589
Steel/Macro/TrussDraws Trapezoid Vault Truss.
590
Steel/Macro/TrussDraws Triangular Asymmetric Truss.
591
Steel/Macro/TrussDraws Triangular Sloping Left Truss.
592
Steel/Macro/TrussDraws Triangular Sloping Right Truss.
593
Steel/Macro/TrussDraws Triangular Symmetric Truss.
594
Home/ModifyLine cuts primitive objects such as arcs to another line or arc.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
595
Modify/Entity Edit/ColumnTrims column edges with an axis or beam.
596
Home/Roof/RoofTrims entities with roofs.
Tools/Tools
597
Home/Wall/WallTrims/extends walls.
598
Home/Roof/Roof DetailsDraws a trimmer.
599
Steel/MacroDraws Custom Truss.
600
Steel/Macro/Single Plate ConnectionCreates a truss connection.
601
Home/Entities/3D ObjectsDraws tube.
602
Steel/Macro/Single Plate ConnectionCreates a tube base plate connection.
603
Tools/EditUndo.
604
Steel/Macro/Single Plate ConnectionCreates an unstiffened seated connection.
605
Drawings/Layout Design/Create New LayoutUpdates linked layout blocks.
606
Home/Entities/LibraryUpdate library elevation.
607
Home/Entities/RailingUpdates 3D railing.
Rendering/Railing/Railing
608
It is located in the ODT door/window toolbar.Use distance.
609
It is located in the ODT door/window toolbar.Use dio as reference.
610
Drawings/HatchDraws user defined hatch.
611
It is located in the tubes toolbar.Draws user defined tube.
612
Home/RoofDraws vault.
613
Steel/Macro/TrussDraws Vault Truss.
614
Home/Roof/VaultOpens vault settings.
615
View/Workplane/Target WorkplaneCreates a vertical workplane.
616
View/ViewOpens view settings.
617
View/WindowDisplay view configuration options.
618
Home/WallDraws wall.
Modify/Wall
619
It is located in the sweep toolbar.Sets wall based.
620
Home/Wall/WallOpens wall settings.
621
Tools/Import-Export/ImportImport .obj files.
ideCAD logo/Import
622
Steel/Macro/Single Plate ConnectionCreates a welded box/tube connection.
623
Steel/Macro/Single Plate ConnectionCreates Welded Connection.
624
Steel/Macro/Single Plate ConnectionCreates a welded flange plate connection.
625
Steel/Macro/Single Plate ConnectionCreates a welded web connection.
626
Steel/Macro/Single Plate ConnectionCreates a wind connection.
627
Coordinate BoxEnters the X coordinate box. X coordinate is entered.
628
Coordinate BoxEnters the Y coordinate box. Y coordinate is entered.
629
Home/ZoneDraws zone.
Modify/Entity Edit
630
Home/ZoneDraws zone edge.
631
Home/ZoneDraws zone hole.
632
Home/ZoneDraws zone list.
633
Home/Zone/Zone EdgeOpens zone edge settings.
634
Home/Zone/Zone HoleOpens zone hole settings.
635
Home/Zone/Zone ListOpens zone list settings.
636
Home/Zone/ZoneOpens zone settings.
637
View/ZoomZooms the window.
638
View/ZoomZooms to the extents of the drawings.
639
View/ZoomZoom selection.
640
View/ZoomZoom into a rectangular window.
641
KeyboardZooms in.
642
KeyboardZooms out.
ideYAPI BIM Knowledgebase Logo
Copyright © 2022 © Copyright 1988 – 2021 ideCAD • Powered by
and
1
ideCAD logo/Import
2
ideCAD logo/Export
3
ideCAD logo/Export
4
5
6
7
ideCAD logo/Export
8
ideCAD logo/Import
9
10
11
13
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
14
15
16
17
18
19
20
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
21
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
22
23
24
25
26
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
27
28
29
30
31
32
Facade/Reference
Concrete/Reference
Steel/Reference
Tools/Reference
Drawings/Reference
33
34
35
36
37
Concrete/Axis
Steel/Axis
38
Concrete/Axis
Steel/Axis
39
40
41
42
43
44
45
46
Facade/Reference
Concrete/Reference
Steel/Reference
Tools/Reference
Drawings/Reference
47
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
48
49
Tools/Tools
50
51
Concrete/Axis
Steel/Axis
52
53
54
Concrete/Axis/Axis
Steel/Axis/Axis
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
77
78
Concrete/Axis/Axis
Steel/Axis/Axis
79
80
81
82
83
84
85
86
87
88
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
89
Concrete/Axis
Steel/Axis
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
Concrete/Concrete
107
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
109
110
111
112
113
114
Concrete/Concrete
115
116
Concrete/Concrete
117
118
119
120
121
122
123
124
125
126
128
129
130
131
132
133
Concrete/Axis/Axis
Steel/Axis/Axis
134
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
166
167
168
169
170
171
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
172
173
174
175
176
177
178
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
179
180
181
182
183
Facade/Reference
Concrete/Reference
Steel/Reference
Tools/Reference
Drawings/Reference
184
185
186
187
188
189
190
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
191
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
192
193
194
195
196
197
198
Facade/Door-Window
199
200
Home/Roof/Dormer
Facade/Door-Window
201
202
203
204
205
206
207
208
209
210
211
212
213
Drawings/Window
214
215
216
217
218
219
220
221
222
223
224
225
Drawings/Text
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
Facade/Modify
Concrete/Modify
Steel/Modify
Modify/Entities
Drawings/Modify
243
244
246
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
247
248
249
250
252
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
253
254
255
256
257
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
258
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
Drawings/Tools
275
Rendering/Tools
276
277
Facade/Modify
Concrete/Modify
Steel/Modify
Modify/Entities
Drawings/Modify
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
ideCAD logo/Import
294
ideCAD logo/Export
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
312
313
314
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
315
316
317
318
319
320
321
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
322
323
324
325
326
327
328
329
Drawings/Primitives
330
331
332
333
334
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
335
336
Rendering/Render
337
338
339
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
340
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
341
342
343
344
345
Home/ModifyMove.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
346
Concrete/Axis/Axis
Steel/Axis/Axis
Modift/Entity Edit
347
348
349
350
351
352
353
354
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
355
356
357
358
359
360
361
362
363
364
365
366
367
367
Home/ModifyOffset.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
368
369
370
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
371
372
373
374
375
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
376
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
377
378
379
380
381
382
383
384
ideCAD logo/Export
385
386
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
387
388
389
390
ideCAD logo/Export
391
392
393
394
395
396
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
397
398
Concrete/Concrete
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
Facade/Railing
422
423
424
425
426
427
428
429
430
431
Tools/EditRedo.
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
Modify/Entity Edit
450
451
452
453
454
455
456
Home/Roof/Roof
Facade/Door-Window
457
Home/ModifyRotate.
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
458
Facade/Modify
Concrete/Modify
Steel/Modify
Tools/Tools
Drawings/Modify
459
460
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
461
462
463
464
465
466
467
468
Concrete/Modify
Steel/Modify
Drawings/Modify
469
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
470
471
472
473
474
475
476
477
478
479
480
481
482
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
483
484
Facade/Edit
Concrete/Edit
Steel/Edit
Drawings/Edit
485
486
487
488
Facade/Modify
Concrete/Modify
Steel/Modify
Modify/Entities
Drawings/Modify
489
490
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
491
492
493
494
495
496
497
498
499
500
Concrete/Concrete
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
528
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
529
530
531
532
533
534
535
536
537
538
539
Concrete/Concrete
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
Tools/Edit
555
View/Window
Drawings/Window
556
557
558
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
559
560
561
562
563
564
565
566
Modify/Entity Edit
567
568
569
570
Facade/Snap
Concrete/Snap
Steel/Snap
Drawings/Snap
571
572
573
574
575
Drawings/Text
576
Drawings/Text/Text
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
Facade/Modify
Concrete/Modify
Steel/Modify
Drawings/Modify
595
596
Tools/Tools
597
598
599
600
601
602
603
Tools/EditUndo.
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
Modify/Wall
619
620
621
ideCAD logo/Import
622
623
624
625
626
627
628
629
Modify/Entity Edit
630
631
632
633
634
635
636
637
638
639
640
641
KeyboardZooms in.
642
KeyboardZooms out.
