I have a project that has a terrace above the 80 cm floodplain after starting from code 0. Since we work on the roof of each floor, when I work on the ground floor, when I make a terrace, I make the balcony of the first floor. So how do I make the terrace? Do we need to show the terrace in static? I thought about switching to architecture mode and defining flooring. I defined the code for it and brought it to the terrace position, but the program sees it as a raft slab. How should I define the terrace?
